Display - Temp & Flow?
18 Oct 2012
Wales
Hello fellow enthusiasts,
I'm looking for a device that will have the capabilities to display flow and a temperature.
If not I can easily display the temp using a small screen, but I cannot seem to find a variety of devices that display water flow.
I'm not looking for a fan controller either. Just temp and flow display.
Any ideas?
Many thanks.
Nick.
TBH i never heard anything about FLOW METER for wc systems AT ALL....
Flow meter would reduce flow itself so that makes it useless kinda.
the only monitoring device that OCUK sells is the aquero - for which you can get a flow meter (though OCUK themselves don't sell the flow meter)
you can also buy flow meters which will hook up to say a fan controller or motherboard header and give you an RPM reading which you can then convert to a corresponding flow value
however, there isn't a stand alone device with a display that will give you just flow, or just flow and temp (there are the XSPC temp sensors with a display that will give you just temp)
setting up any kind of flow meter was looking like it was going to cost about £100 so I just gave up on the idea
Koolance do them on their website if you google "Koolance Flow Meter Adapter With Display". This is the display and, as in the description, they require the sensor. Seems like it will do what you want
Don't know if you will find them on a UK website though.
OCUK should really stock these kind of things more as i'm sure they are useful top many people
I have found it in the UK but it works out around £70 which is quite steep for what it is
