Displayport Cable
29 Sep 2004
Wilt of the Shire
I need to get one of these for my monitor. I have seen a 1.1 and 1.2 cable, is there much difference between them? It's to connect my 1900 x 1200 monitor to my GTX 670.
1.2 has more bandwidth and supports some more things (more color profiles, more bit depth, higher resolutions, daisy chaining) you won't be using with a GTX670/1920x1200 monitor. As the poster above did, just buy the cheapest cable you can find.
