I need to connect a new(ish) graphics card which has 2 x Displayport and 2 x HDMI outputs to 2 x 1080p older monitors which only have DVI-D inputs.
Could anyone answer a couple of questions please?
Is it better to use the Displayport or the HDMI outputs on the graphics card?
If using the Displayports, will a passive cable/adapter work or is it likely that I'll need an active adapter?
Advice much appreciated.
Thanks
Thanks
