DisplayPort to DIV adaptor for Eyefinity
11 Aug 2007
Preston, Lancashire
Where can I find an ACTIVE DP to DIV adapter for using with my third 2407wfp-HC monitor for an Eyefinity set up?
Thank you
Farore
Either from Dell US who don't ship to the UK, or from a certain dutch site, you will have to google. Bizlink adapters etc.
ALso there is a Apple adapter that may work, its approx £68+, but there is a big list of monitors it does't work with.
I've looked into the Apple adapter and there appears to be quite a few issues with it. I'd steer clar unless you can confirm 100% it works fine with your setup.
I think it does work, as there is people using it.
Although i think its extremely pick with which monitors you use. Although with what system you are running.
I'm sure you can test it out, and just take it back if it doesn't work.
thats cause they want you to spend over £400 on a new monitor
yea but surely Accel/Bizlink dont! Wish OCUK would get on this!
Wow that Dutch site keeps bumping the price :eek:
Edit: No longer listed on Dell site, guess they decided it was reducing potential DP monitor sales :angry:
Are there any 20" monitors with DP?
