Displayport to HDMI Not Working
25 Oct 2004
Cambridge
Hi,
I have an old Samsung 32" LCD 1080p TV that I was going to use with my MBP to watch film on using a mini displayport to HDMI cable.
When I first used the cable it worked fine, then I thought I would test a film so fired up youtube and it stop working and the TV said 'mode not supported'. I've tried to fix it and read a few thread but noting seems to work, at best I get a couple of flickers when I play with the display settings.
Any ideas?
Thanks,
Spamalot
Hi, they were cheap. Is it the tv or my laptop that'd need changing to 720p?
Thanks
So more than £20 or so?
Take a look in the 'Displays' pane within System Preferences on your Mac. You'll be able to set 1080p/720p or a load of other resolutions for your TV.
