Displayport to VGA adaptor?
This is the one I got:
About £22 inc delivery to NL from the UK (way cheaper there :) ) Works perfectly.
*Edit* I should also mention that, I believe, these passive adapters only work up to 1680x1050 or something. Not true HD (I could be wrong though) If you have a larger monitor it might be worth doing some more research. I use 3x1680 so it's not an issue for me.
