Displsy Port 1.4 vs 1.2- is 1.4 that much better?
22 Apr 2020
All
i know almost nothing about monitors
I am having a custom rig built and with Ryzen 9 3600, RTX 2060 super.
i just bought a monitor because it has G-sync it was ASUS VG278QR (£250). but i just learned its display port is 1.2 and not 1.4.
To be able to return the monitor and get a refund for something with 1.4. i need to know within days if i should keep it or return it.
I need a monitor to be at least .
G-Sync compatible
27"+
144mhz refresh rate
Playing online games such as world of warships/total war etc and maybe more in future.
I like the option of 4k now in monitors, but when will i use this i gaming? if ever. I do not know.
As i do more research on monitors i think i need one that has a 1.4 display port to make best use of gaming when using the RTX 2060 super?
I cannot work out if i will need a better monitor with display port 1.4 or keep the new one that i have. this ASUS VG278QR has a refresh rate of 165. Will my rig be able to give me a better gaming experience but held back by the display port 1.2?
Is 1.4 that much better for gaming than 1.2? If so, by how much benefit will i get?
Should i send back the ASUS VG278QR and get a refund and opt for either of the below:
Pixio prime PX7
LG 27GL83A-B
LG 27GL850-B (might be to costly)
LG 27GL65F-B
Max i want to spend is £400
I have bought a Display port cable that handles 1.4 in preparation.
thank you all
1.2 does 4k @ 60Hz
1.4 does 4k @ 120Hz+ I believe.
So it all depends on if you want a refresh rate above 60Hz at 4k.
Displayport 1.2 is fine for that monitor. For high refresh 1440p and up you want DP.1.4.
4K high-refresh-rate gaming is a reality now. And it's great! And your 2080 Super is more than capable of it. The LG 27GL850-B is a much better fit than that 1080p monitor. I use an Acer Nitro 4k which is well out of your price range.
Thank you gents
I prefer 1080 reso. What I want to make sure is that my games when on highest possible setting using 2060 super wont have issues reaching over 144mhz on the asus monitor with DP 1.2. Because I want to use g sync I want to use display port and not hdmi.
I dont think I have games in 4k range yet. Yet though.
So with all that said are you all agreed that my current asus monitor is fine?
Many thanks
