I took a BMW to a BMW specialist who had a few online forum recommendations. I was warned he was expensive, but I had taken it to other garages who had done a crappy job so just bit the bullet.
The problem was a red warning on the dashboard of a steering wheel and a lock.
They plugged it into the diagnostic system and he said it came back with "change cheapest component" which was apparently the CAS module which costs £245+VAT (plus fitting)
So the red warning light went away for 3 weeks but now has reappeared on the dashboard.
So I took it back and he says that that means the steering column needs changing. He offered to install it for free, but I would have to pay for the additional part which is in the region of 300-400 (waiting for an exact quote).
He was the one who recommended the CAS module. He appears to not have the old one so can't exactly put it back in. and he is passing the back to my car which gave him the message to just change the cheapest component.
But technically should he be responsible in refunding me for the CAS module?
I did get him to change brake disks, pads, tyres, and a full service. So I did spend quite a bit of money with him and have used him before.
It has not turned into a full dispute yet, still just waiting to confirm the cost of the new part then I can negotiate fully. Any advice on how to approach or negotiate would be helpful. Ideally I would just like to pay the difference between the two parts.
Thanks.
Thanks.
