I know there a few decorators, painters who lurk on here, need some professional advice, about distemper paint, NOT the Canine Distemper.
Got a large ceiling, plus a long hallway ceiling which has been painted with emulsion, which is now peeling due to the original distemper underneath.
Had to strip four other ceilings because of the peeling paint, been using 'Artex Stabilex' to seal the powdery & porous ceilings before repainting.
Is there any other product you can used, instead of Artex Stabilex, which is £35 a 5ltr can, used two cans so far.
, will need another two cans I thinks.
Using PVA will not work, it's totally unsuitable on distemper.
