Is there anything wrong with adding distilled water to pre-made coolant?
I'm upgrading and adding another rad to my loop and dont think I have enough spare coolant to fully fill the loop again. The coolant is only a month or two old anyway. Is there anything wrong with just adding a little distilled water to it? The dye isn't a problem as the amount I will use wont add significantly much to the loop.
