Anyone else noticed this?
I've been doing a new build and loved my old 800D so I thought I'd try some of corsairs other offerings...
I started with the 540 air, the first one had broken hdd caddies on arrival and a ridiculously noisy fan (bad bearing perhaps). Returned
The second 540s side panel only fits with the screw in diagonally and the cable tidys tear when you push your cables through and finally it develops a loud case vibration rattle because the front and top panels don't fit tight enough. Returned.
Next I order a 750D and it arrives with the front panels not latching as a catch is broken.... about to be returned...
Really annoying as I'd like to finish this build sometime this year.....anyone else having issues?
