- 2 Apr 2007
- North Shields
Yep Yep Yep, my trusty old P5N-E SLI has beeen put in with some of the girlfriends kit.
-Q6600
-4Gb Crucial Ballistix
-560ti 448.
Basically her motherboard was giving her blue screens and all sorts of hassle, was an OEM board, so thought my P5N-E SLI would do the trick since it has worked for years without problems.
I built the new machine in an Aerocool case.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-AE&tool=3
Now this is the issue, I noticed when running the Heaven DX11 benchmark, the sound is all distorted. So i tried the back panel audio jacks directly from the motherboard. Exactly the same. Then i tried in my macbook, sound was perfect.
What gives?
-Q6600
-560ti 448.
What gives?
