- 29 Feb 2012
- London
Does anyone here know what ddc pump will fit the Barrow distro block for a evolve X?
Thanks
Thanks
DDCs are a standard size so all of them will fit the distro is it's DDC enabled.
The only thing to consider is how much space you have in the rear as DDC heatsinks are different thicknesses.
Could anyone help here
I have a distro block for my evolve x from Barrow.
(It doesn't come with instructions)
It comes with a 3 pin 5v head for the led's.
Its say not to plug it into the 12v motherboard header.
What can it be plugged into?
I have phanteks fan hubs, do I need to buy something else?
3 pin 5v means it's got individual controllable leds
Need a 5v 3 pin addressable led header on your motherboard
No they dont all have an addressable header mainly the more recent boards have themThank you
Ok I'll check the mobo book, but I'm not sure I saw one.
I'm guessing they all have at least one?
The Z390 Aurous Master will have them, just going to check the mobo manual, brbCould anyone help here
As I thought, you have 2 places for 3 pin 5V addressable LEDs, D_LED1 & D_LED2.
Bottom left of the board and top right respectively![]()
Best get some pics up, sounds like you need an adapter?Thank you dude
The 3pin connector looks like the 4 pin pwm that came with my ek vardar fans.
Ill have to get a picture of the lead that came with the distribution block.
I know the spots your talking about.
Annoyingly the barrow distro block didn't come with instructions.
I will do dudeBest get some pics up, sounds like you need an adapter?
A distro block and a reservoir are different things. A lot of these new commercial ones blur the lines somewhat by incorporating a large chamber which acts as a reservoir, but it's still not a res in its own right.Apologies for hijack. Is the lower volume of fluid in these distro reservoirs compared with a traditional cylinder reservoirs a problem? Increased temps?
