Distro Recommendation Needed
30 Dec 2004
Bromley, Kent
Hi guys,
Looking at gettign an Acer One and using a different distro on it. The problem is that I can't find one that is a very lightweight GUI edition but without bundled stuff like word processors, media players etc. All I want is basically the shell and then the ability to add in everything else after. So far I've seen slax, DSL and xUbuntu but they still all seem to come with stuff (althogh slax and xubuntu are looking good). Any recommendations on the least cluttered distro? Preferably something reasonably easy to add apps too aswell :)
Cheers
- Pea0n
Arch linux would get my vote. Install the base and then add xserver etc as you see fit
Distro doesnt really matter in terms of a GUI because you can use any DE/WM you want.
Ive never added or removed any GUIs or changed them in Linux so I'm not really sure how you mean by DE/WM, got a link?
Cheers for Gentoo and Arch, saw that around and I'll give them a closer look :D
Keep them coming, I'll probably try a few out
- Pea0n
Gentoo or arch (but it will take some time to set it up propperly and get it light weight). EDIT: way slow a typing
That said if you follow a few guides of how to do gentoo propperly its really easy to get a very fast system on a low spec machine (i had a really good setup on an old p2 machine using xfce4 for my desktop) and emerge is one of the best tools for adding and removing programmes to :)
Well i just had a look over a few guides for installing Arch with a USB stick, unfortunatly it seems to show how to set the USB stick up form linux rather than from XP so I'm lost on how to do that. Gentoo looks interesting but I get a feeling arch would be very very good for my needs if i got it working.
-Pea0n
-Pea0n
You'll boot from the USB stick, instead of within XP. So technically, it doesn't matter that the instructions are not XP related. All you need to do is copy the contents of the iso to the stick.
Cheers for the link Ethics,
Jestar - Realised that with the link. The console commands it was using were confusing me as I had no idea what it was doing, but if it only has to be extracted to a USB stick then thats defo easy enough :)
I'll download both tonight and have a play in VirtualBox to see whats hot and not. Just need to wait until pay-day before I can grab my One now :(
- Pea0n
Not been in this forum for some time - or even Overclockers for that matter. it's strange how over time distros become in/out of favour.
From my experience for home desktop usage it has to be Ubuntu. I've just installed version and 8.04 and I'm frankly astonished at how good it is. In terms of looks, ease of use and installation.
Historically, I've used Fedora and SuSE - they always seemed bloated and slow.
