Hi Guys,
TLDR; My tyre garage experience made me think what others were using in the spare tyre well in the boot when switched to non run flats.
I ditched the Run Flats on my e92 about 7 months ago now and haven't looked back since, the quality of ride is so much better. At the time I also had the wheels refurbed.
This last week I noticed a bit of a wobble and suspected the loss of a wheel weight and took it to a local tyre guy who has a pretty good rep around here. Well, to say he was not happy with the fact I'd swapped out the run flats is an understatement, initially telling me the car is now illegal because my insurance is void. After I pointed out I had written confirmation from my insurer advising switching to a non RFT was not an issue he did, unwillingly, retract his statement. During this time, his staff were fitting the wheels back to the car without balancing as he wanted nothing to do with it.
He went on to explain that the construction of RFT wheels is different with a lip being the rim that accommodates for a much wider, thicker RFT sidewalk which leave a large gap for standard walled tyres to "flop" around in, rendering a high chance of the tyre popping off the rim during cornering. Now I felt lucky to be alive after driving round in such a death trap for the last 7 months
The only evidence I found previously is that there is an extra lip inside the rim of an RSC enabled wheel to restrict movement of a deflated RSC tyre. for this reason, you can not fit run flats to a standard wheel although fitting non flats to an RSC enable wheel is fine.
Now to my point that cropped up after this: I did the usual general internet research for quite a while before making the swap and have a continental mobility kit in the boot and also RAC cover in the event of a destroyed tyre. What kits do you guys use mobility kit and a jack? just mobility kit? purchase space saver?
Thanks.
Thanks.
