Divx converting
27 Sep 2005
Cornwall / Helston
Hey guys, i've got a divx movie on my PC that i would like to play on my TV but my DVD player does not support it, is there a way i can convert it to a DVD format whilst retaining its quality so it can play on my standalone player?
Boo
edit: ok i just done a google and there is loads but what is a good program to use?
Boo
For AVi's "convertxtodvd" is a must, I would imagine it supports that format also?!?!
Install, drag and drop file into convert windows, hit convert......hit burn and your there!!
i only use this program and DVD santa has rubbish demo band around sreen when playing and you can add back grounds, sub's and all sorts with ConvertX
give it a whirl! :)
i've used nero vision and winavi in the past both worked well, nero vision has menu creation (perhaps winavi does too, but i missed it), but winavi is faster
evulboo:
WinAVI, Tmpgenc 3/4 Xpress, TMPGEnc Plus 2.5, etc, the ones from TMPGEnc (Pegasys) seem to be extremely good, encode AVI into MPEG2 then DVD Author is required to provide DVD Video Files for burning onto blank DVD media. :)
ConvertXtoDVD does exactly what it says on the tin :) really pleased with it so bought it
Thx for advice
Boo
same as this guy
give it a whirl! :)
Hi there this is true ,its not free ,but i use a program called Covertxtodvd its very good ,will put menus on abd a background you choose,it converts avi to dvd ,i have used it ,and they play on my dvd player no trouble :)
