DIY Buttermilk
7 Aug 2012
Hi All,
I've been looking at some rather delicious (yet incredibly unhealthy) recipes for doing some southern fried chicken.
The majority of the recipes state that you need buttermilk. I've had a look on Asda and Tesco to see what they offer and to buy a bottle of buttermilk isn't that cheap and I'm not sure all stores will stock it.
I've had a look online and there's a few people suggesting using full fat/whole milk and lemon juice, I was wondering if anyone had used this method before and how did it turn out?
Cheers
Swain90
I'm not convinced you do need buttermilk for fried chicken. If anything, substitutes are going to be even less discernibly different in that than in a baking context.
it adds a bit of a sour note, hence the suggested substitute.
As others have said just ignore it and use what you want or use the substitute.
buttermilk is not so expensive 50p 300ml - i use it in American pancakes - but for fried chicken, the thicker consistency of
genuine buttermilk or yoghurt is going to help more coating stick ? (in addition to its acid tenderising the meat)
where in the supermarket would u pick it up at?? the fresh dairy section or the home cooking/world sauce section.
its something ive never bought before
In fried chicken doing this might not be too bad, but in baking it's really not such a good idea:
http://www.seriouseats.com/2017/04/how-to-substitute-buttermilk.html
If you really want to do DIY buttermilk because you can't find any, you can make it by separating cream. Get loads of double cream, stick it in a blender for a while, eventually it'll separate and you can pour off the buttermilk and wash out the remaining butter
ah nice little tip there. thank you very much for that
in baking the buttermilk (acid) is generally used in conjunction with bicarbonate of soda (alkali) for rising purposes,diy buttermilk with lemon will also leave a taste for baking
double cream is 70/80p for 300ml so much more expensive than buttermilk , don't know what the buttermilk yield is ? - hopefully the solid part is useable (... a diy clotted cream ?)
Sainsbury's sell buttermilk that is pretty well priced, used it for a few different recipes and they've turned out fine using it. It's 75p for 300ml and is usually in the aisle with all the single/double creams etc.
For anyone that's interested, I managed to find some buttermilk in Tesco. Was 50p for about 250/275ml so wasn't expensive!
The chicken turned out OK. I didn't get enough oil so the chicken ended up sticking to the bottom of the pan while I was sorting something out so it was a little burnt, so if I was to do it again i'd probably get more oil and also probably do chicken strips as doing an entire chicken breast takes a while to cook. But the actual recipe tasted guuuuuuuurd!
