DIY Framing
25 Sep 2003
Im thinking about framing my Alan Shearer Testimonial things as at the minute everything is just squashed in a bag, and i would like them on show. The things id like framing include the Programme, Ticket Stubb and Scarf. I have no idea what ill need so if anyone on here could give me an idea on what i will need and maybe a suitable frame. I would be grateful
wood, glass and another wood/mdf/etc back to the frame...
glue,etc .... should be toooo difficult - glass maybe the most annoying part to work with?
Making a frame isn't too hard if you got a few DIY skills.
Get a bit of molding you like the look of
Cut a notch out to hold the glass. -hardest part
Cut the mitres for the corners, remember its the inside measurement you want. - getting the mitres tight can be hard.
glue it together
shove in glass
add stuff into frame
