Evening all,
I don't want to go into too much detail, because if it works I'll do a full writeup for on here, so I don't want to spoil the surprise (then again, it might fail terribly).
I'm going to want to take a small Al or Cu block and add some fins to it. I was wondering if anyone on here had dabbled in this before (other than the HUSH Project). My current thoughts are to cut very fine slits in the block, fill the slit with TIM, insert a fin made of aluminium drinks can, and then on the top surface of the block, where it meets with the fin coming out of the slit, secure the two together with solder.
My hope is that the snug fit of the fin within the slit, coupled with the TIM, will give a good thermal path through to the fins, and the solder will physically secure it.
Also, does anyone know when preference moves from a solid piece of copper to a copper heatpipe in terms of being able to conduct heat between sites? I may want to bridge a couple of heatpipes over a distance of around 1-2inches, but I'm not sure what the criteria are to select between heatpipes and solid copper.
Thanks for any and all advice guys!
