DIY Help
~J~
~J~
20 Oct 2003
London
OK calling all you DIY experts.
Got a wee problem here and baffled how to proceed.
Please excuse my lack of technical know-how in the correct terms, will try and explain best I can.
Have a door with a lock on it, and am having to change the lock for a new mortice one.
The 'metal plate' on the side of the door which houses the lock itself is about 6" in height.
The bottom part of this plate is where the 'lock' itself goes into the door frame, the top part is a handle which again contains the latch(?) that acts as a double lock.
Now I'm trying to remove this plate but can't because of the following:
If I remove the handle to the door, the 'hole' of the handle fits into the common square shaped peg to turn the latch.
And I need to remove this 'square shaped peg' because that fits into another square-shaped hole which inturn is attached to the door lock.
The 'square shaped' peg however is so old and rusty behind the handle that I'm having difficulty getting it out.
So my question is, what's the best way to remove the "square peg" in order for me to remove the entire metal housing?
Tried a simple monkey wrench an tried to do it as tight as possible onto the 'square shaped peg' but each time I pull the wrench to try and pull the peg out, it just comes off.
Any thoughts?
(have tried kicking it in the ovaries and nuking it from orbit)
Let me get this straight. You are trying to pull something out by finger-tightening a monkey wrench to it?
Ever heard of FAIL?
Try some mole grips.
Try a bit of penetrating oil on the square rod where it enters the lock then leave it for a while and give the end a tap with a hammer.
Ever heard of FAIL?
Heard of it, experiencing it.
Will try these mole grips that you talk about.
take the handle off both sides this will give the metal rod freedom hit either side with a hammer the rod should move freely frim either side.
This thread makes no sense, are you saying the spindle is stuck through the mechanism?
If so...just bang it out with a hammer :confused:
Like has been said, soak it with WD-40/GT-85 or whatever you have on hand, leave it for a few mins, give a few taps perpendicular to the shaft to break the rust then try driving it through the hole with the heaviest hammer/mallet you have.
