Finally moved house (woo!), but looking to lay my own network around the house. Never done this in my residential properties before (either been wired prior to me living there, or did it previously in industrial premises).
I'm weighing up several things which i'd appreciate some recommendations for:
1. Cat5 v Cat6
I appreciate Cat6 is better RF shielded (and potentially more able to handle extreme temp variations), but would it be better to lay Cat6 at this early stage instead of rewiring at a later date if bandwidth or shielding ever became an issue?
2. Crimp Tool
I'd like a reliable (i.e. lifetime) tool to strip and crimp (ideally and a pushdown tool) - does any manufacturer or kit stand above the rest in this regard? (at work we use the worst gear and buy replacements every few months)
3. Cable tester
As above, anything that stands out above the rest?
Good value for money is my key!
Thanks in advance
1. Cat5 v Cat6
2. Crimp Tool
3. Cable tester
Thanks in advance
Even if you only hide the spare ones, I bet that they will be used before you have opportunity to re-cable again.
