Permabanned
- 15 Nov 2011
I want to use some of the parts i have already to build a nice sealed system. Better than a H60/H80. I need to make something as small as possible.
Parts i got are
Akasa Viper 140mm X2 fans
Laing DDC 18w pump stock top
DT Snipper block
I have 3.5'' between my case floor to mobo. There is a 140mm fan already mounted under the case foor so offering a 2nd within the case is an option only.
I'm thinking of using a bracket on the rad to mount the pump.
Modded top on the pump, G1/4'' and looks nicer along with the performance.
So i need to sort a rad out, what size tubing to use and how to make this one simple system.
Is there a rad that has a bleed on it? My idea was could fill the system and bleed it via bleed nipple.
Any other ideas? Need to be as small as possible
Parts i got are
DT Snipper block
