Morning,
Seeing how helpful my last DIY question on here was I thought it go for another (we really need a DIY forum please!).
Ok so its now 4 weeks till move in and we dont have a kitchen or bathroom or any rooms finished but I have got some pipework sorted..ish.
I'm looking to install a shower pump for a thermostatic mixer shower and am a little confused where to put the pump, the options are:
1. Install the pump at the base of the hot water cylinder in the airing cupboard, its very tight but could just about fit. This would then pump the cold and hot up into the loft, across the loft and down in a wall to the mixer.
2. Install the pump at the base of the bath/under the shower. Cold feed is simple, straight down from the loft. Hot would need to be connected up into the loft and then down, would this cause issues? Pump then connects back into the wall and up to the mixer.
3. Install in the airing cupboard, pipes then run into the floor and pop out from the floor under the bath and up to the mixer, wouldnt be an overly straight run due to the joists and such.
Any help would be appreciated.
NB. Electrics are easiest for the under bath connection to pump.
