DIY Side Window
10 Apr 2015
Hungerford, UK, Earth
I have a Fractal Define R3 , The Side panel with a window is no longer available either new or second hand..
are there any DIY window kits out there that give a decent result, ive seen a few where they cut and put some moulding around it, but it doenst look great ie wobbly :(
Shouldn't be too hard to do if you fancy a challenge ;) I plan on modding my case soon, including painting it white :p Or maybe I should just buy a Fractal? :D
fractal are good cases i have 2.. i dont know why OC dont sell any fractal gear.. maye the margins arent good on them
Nah they used to but not anymore, AFAIK it was a quality control problem, there's a thread about it somewhere :p
