Hey guys, I remember reading a while back that car heater cores were good for WC rads. Anyways, just ripped the heater core, the pump that was attached to it and a power-steering reservoir out of a Ford Focus. So my questions are:
1) Is the stuff listed OK to use in a WC setup?
2) Recommendations for a cpu block.
3) The pipes before the barbs are fairly long, how would I go about replacing the barbs?
The heater core is the width of a sheet of A4, and only slightly shorter. Looks to be made of Aluminium, so that means I should get an Alu CPU block also, right?
