- 7 Feb 2004
- North East
Anyone any ideas where id buy some copper block online (about 7" x 7"x 3/4" , 2 of those) in the uk ?
Is block what i should google, or is plate or something a better description ?
the plan is...
drill a block as above, channels with a large drill bit, tap where the drill enters the block with 1/4" tap, and add barbs or bungs where relevent (bungs would be countersunk) ... the small dots would be drilled through, and allow 4 HDDs to be screwed onto the plate, this would then be enclosed in a alu box, and completely matted with foam, with only a hole for the cables, and barbs exiting, would then be mounted in 3 5.25" bays...
would this VERY simple waterblock cool 4 drives ? Given no air would be circulating, and the drives would be cooled from the sides, and the tops would almost be touching...
does this sound a bit far fetched ?
Any better ideas, or anyone tried anything like this ?
the plan is...
