DIY Watercooling
17 Dec 2005
I really want to try and make my own watercooled system and I have an idea to mount all the rad, res and pump away in a seperate smaller chassis under my midi tower.
The only problem I have at the moment is I'm a little unsure what cpu/vga block, pump etc to use, pointers/recommendations needed.
I plan on getting a dual rad Seeing as I would have ample space to mount it in the second chassis. Although may be overkill for my system.
Budget for complete system £100-£150.
Apogee cpu block ~30
Pump you'll want a Laing D5 ~50
and Vga block a DD Maze 4. ~30
Thermochill PA 120.2 rad - ~50
Normally i'd have said the Storm cpu block but it'd put you way over budget. Though you could also get the Swiftech MCR220 rad which is only 30 for cut costs
