Hi guys,
Does anyone have much experience with this? Either with the string method or buying tools to do it yourself?
Reason for this is a while back I changed the suspension on my MX5 for some Koni Coilovers which i'm very pleased with. Aftwerwards, I wasn't able to immediately get a wheel alignment done, and noticed a bit of inside wear.
Then I got the alignment done, and some time has passed and I have recently noticed that the inside wear has progressed to the point of concern. I don't think the garage in question who did the alignment did much if anything. At this point i'd be inclined to go back and have a moan, but I no longer live anywhere near them and to be honest, can't be bothered to travel a long way just for an argument.
So, without waffling on, given that I seem to be finding it difficult to find trustworthy garages in general (and doing most of the work on my cars as a result), I live in the middle of nowhere, and that i'm 20 minutes from the nearest racetrack (Mondello), I'm investigating as to whether it makes more sense to get some equipment and do it myself so at least I know it's been done to the best of my ability (which I can live with).
I know perhaps it won't be as accurate as a laser alignment, but given that I have two cars that I intend to track, I'm figuring it will pay for itself very quickly, and give me the opportunity to play around with different setups moving forward.
So, does anyone have any experience of this, and furthermore, any recommendations of equipment?
Wouldn't want to spend more than around 200 quid, and i'm looking at being able to do all 4 wheels, camber, castor and toe at a minimum.
Thanks
Thanks
