I have a spare set of BBS split rim alloys, I want to spray them white.
Do I have to strip them down to the bare metal first. or can they be just be sanded briefly then primed straight off?
Im going for a gloss white, using a halfords white primer as the base. As for the paint itself, will regular panel paint do? or does it need to be tougher paint on wheels? Same goes for the lacquer. Also is there any point in going for more expensive paints etc, Im happy enough using halfords own, but if another brand will give better results im all ears.
Thanks
Thanks
