DJ Advice
24 Sep 2003
Bedfordshire
Hi,
I'm tempted to try and bit of DJ'ing (just for fun, at least initially) now that I've got more into my music.
I was just wondering if anyone has used software (most of my music is on my PC) with a hardware mixer to do this and if so does it work well (enough) and what is recommended.
Any help appreciated.
Just for info my main music interests are: house, trance and electro
Cheers,
aaazza
i used traktor and virtual DJ with an external mixer, it was good but its not even close to a proper set of decks when it comes to satisfaction and enjoyment
imo anyway
i would get virtual dj and a mixer and hook it up through the front/rear outputs of your sound card (providing its 5.1)
ableton live is probably the best software but its more for planned mixes with re-edits etc rather than sporadic mixing
Thanks for the info, will check it out.
Any recommendations on mixers? Obviously not after anything for mega-money.
Cheers,
aaazza
Not sure tbh, my experience is fairly limited. I would have thought a traditional one, that could give me the option of plugging into decks in the future.
Thanks for the reply,
aaazza
virtual dj is definetly where its at
ableton afterwards , easyish to use but wont teach you much about dj ing , also very expensive
virtual dj or traktor wont teach you any more about djing more than ableton really imo
either way if you can pull off a good set on the pc theres no reason why you couldnt on vinyl/cd once you've got cueing/beatmatching sussed
Thanks for all the responses guys.
Now looking to source myself a mixer, think my mate has got one he is not using which would be good for a mess about.
Cheers,
aaazza
