Is anyone familiar with these? It's the first one I've looked at. I'm thinking it's a RAM issue but can't be certain?
Thanks
Code:
Microsoft (R) Windows Debugger Version 10.0.14321.1024 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\administrator\Desktop\012117-42416-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: LanManNt, suite: TerminalServer SingleUserTS
Built by: 7601.23572.amd64fre.win7sp1_ldr.161011-0600
Machine Name:
Kernel base = 0xfffff800`02015000 PsLoadedModuleList = 0xfffff800`02257730
Debug session time: Sat Jan 21 15:25:41.750 2017 (UTC + 0:00)
System Uptime: 0 days 2:18:41.426
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {10, 2, 0, fffff88001216208}
Probably caused by : storport.sys ( storport!RaidUnitReleaseIrp+38 )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000010, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88001216208, address which referenced memory
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 7601.23572.amd64fre.win7sp1_ldr.161011-0600
SYSTEM_MANUFACTURER: HP
SYSTEM_PRODUCT_NAME: ProLiant DL380 G7
SYSTEM_SKU: 470065-375
BIOS_VENDOR: HP
BIOS_VERSION: P67
BIOS_DATE: 01/30/2011
DUMP_TYPE: 2
BUGCHECK_P1: 10
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff88001216208
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800022c1100
Unable to get MmSystemRangeStart
GetUlongPtrFromAddress: unable to read from fffff800022c12e8
GetUlongPtrFromAddress: unable to read from fffff800022c1498
GetPointerFromAddress: unable to read from fffff800022c10b8
0000000000000010
CURRENT_IRQL: 2
FAULTING_IP:
fffff880`01216208 488b5610 mov rdx,qword ptr [rsi+10h]
CPU_COUNT: 8
CPU_MHZ: 854
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 1a
CPU_STEPPING: 5
CPU_MICROCODE: 6,1a,5,0 (F,M,S,R) SIG: 19'00000000 (cache) 15'00000000 (init)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT_SERVER
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
ANALYSIS_SESSION_HOST: CHUBBS
ANALYSIS_SESSION_TIME: 01-21-2017 18:47:22.0071
ANALYSIS_VERSION: 10.0.14321.1024 x86fre
TRAP_FRAME: fffff8000351f8a0 -- (.trap 0xfffff8000351f8a0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffffa803dbee6d0 rbx=0000000000000000 rcx=0000000000000000
rdx=fffffa803dbee600 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88001216208 rsp=fffff8000351fa30 rbp=fffffa803dbee600
r8=fffff8000351f9d0 r9=0000000000000000 r10=fffffa801945db10
r11=fffff8000351faa0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
storport!RaidUnitReleaseIrp+0x38:
fffff880`01216208 488b5610 mov rdx,qword ptr [rsi+10h] ds:00000000`00000010=????????????????
Resetting default scope
DPC_STACK_BASE: FFFFF80003525FB0
STACK_OVERFLOW: Stack Limit: fffff8000351ffb0. Use (kF) and (!stackusage) to investigate stack usage.
LAST_CONTROL_TRANSFER: from fffff800020849a9 to fffff80002085400
STACK_TEXT:
fffff800`0351f758 fffff800`020849a9 : 00000000`0000000a 00000000`00000010 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff800`0351f760 fffff800`02083620 : 00000000`00000000 00000000`00000000 00000000`00000000 fffffa80`1d7f8160 : nt!KiBugCheckDispatch+0x69
fffff800`0351f8a0 fffff880`01216208 : fffffa80`3dbee600 00000000`00000000 fffffa80`3dbee600 00000000`00000000 : nt!KiPageFault+0x260
fffff800`0351fa30 fffff880`0121bfd1 : fffffa80`1945db10 00000000`000000fa fffffa80`1d7f8160 fffffa80`1d7f8160 : storport!RaidUnitReleaseIrp+0x38
fffff800`0351fa60 fffff880`01204ee5 : fffffa80`1d7f8160 00000000`00000001 fffff880`01250300 00000000`000000fe : storport!RaidUnitProcessBusyRequest+0x81
fffff800`0351fad0 fffff880`01202866 : fffffa80`1945db10 fffff800`02605895 fffff800`000000fb fffffa80`18eea040 : storport! ?? ::FNODOBFM::`string'+0x1606
fffff800`0351fbb0 fffff880`012094be : 00000000`00000001 fffff800`000000fb 00000000`001fc7d5 00000000`00000001 : storport!RaidUnitCompleteRequest+0x3a6
fffff800`0351fc90 fffff800`0209007c : fffff800`02203e80 fffffa80`18eea000 00000004`00000001 00000000`000000ad : storport!RaidpAdapterRedirectDpcRoutine+0x4e
fffff800`0351fcd0 fffff800`0207d10a : fffff800`02203e80 fffff800`02211cc0 00000000`00000000 fffff880`01209470 : nt!KiRetireDpcList+0x1bc
fffff800`0351fd80 00000000`00000000 : fffff800`03520000 fffff800`0351a000 fffff800`0351fd40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
THREAD_SHA1_HASH_MOD_FUNC: af46fc2a0695d8dd5e1f50cce6d342e2c711319d
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: c0309e8c5ff5d6b15111d72c1bc63b337f9c1e6e
THREAD_SHA1_HASH_MOD: 26f2c98289d095ee5edc151846c8346ca735bed1
FOLLOWUP_IP:
FAULT_INSTR_CODE: 10568b48
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: storport!RaidUnitReleaseIrp+38
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: storport
IMAGE_NAME: storport.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 52f04432
IMAGE_VERSION: 6.1.7601.18386
FAILURE_BUCKET_ID: X64_0xD1_storport!RaidUnitReleaseIrp+38
PRIMARY_PROBLEM_CLASS: X64_0xD1_storport!RaidUnitReleaseIrp+38
TARGET_TIME: 2017-01-21T15:25:41.000Z
OSBUILD: 7601
OSSERVICEPACK: 1000
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 2
OSPLATFORM_TYPE: x64
OSNAME: Windows 7
OSEDITION: Windows 7 LanManNt (Service Pack 1) TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2016-10-11 15:57:55
BUILDDATESTAMP_STR: 161011-0600
BUILDLAB_STR: win7sp1_ldr
BUILDOSVER_STR: 6.1.7601.23572.amd64fre.win7sp1_ldr.161011-0600
ANALYSIS_SESSION_ELAPSED_TIME: 631
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:x64_0xd1_storport!raidunitreleaseirp+38
FAILURE_ID_HASH: {0bada84e-b975-e7ac-60de-9bdf17817e88}
Thanks
