recently moved back from 4K -> 1440p & was wondering if DLSS was still worth it for FPS/quality/temperatures.
even though it renders lower resolution, i was wondering if the AI compute was still keeping stress else where on the card & affecting temperature
this is not fully scientific but its good enough for myself & wanted to dump info here in case it helps others
MSI 3090
God of war
Max settings
only change was DLSS
HwMonitor for measurements
break between testing of 5 Minutes to equalize temps
same scene in God of war
capped to 100fps, (was used for other testing but limits difference in scope either way)
Native 100FPS constant
watts Min: 245W
average 250W
Watts Max 324W
Temperature 68C
DLSS Quality - looks at good at Native 100FPS constant
watts Min: 175W
watts average 185W
Watts Max 215W
Temperature 64C
DLSS Balanced - looks worse than native 100FPS constant
watts Min: 165W
watts average 178W
Watts Max 205W
Temperature 63C
DLSS Performance looks worse than native 100FPS constant
watts Min: 135W
watts Average: 144W
Watts Max 165W
Temperature 59C
conclusion moving to DLSS Quality, would make your rig more silent in theory & cost efficent, but needs more games tested to validate.
MSI 3090
God of war
Max settings
watts Min: 245W
average 250W
Watts Max 324W
Temperature 68C
watts Min: 175W
watts average 185W
Watts Max 215W
Temperature 64C
watts Min: 165W
watts average 178W
Watts Max 205W
Temperature 63C
watts Min: 135W
watts Average: 144W
Watts Max 165W
Temperature 59C
