Can someone suggest the optimum settings for the items I have circled?
I have read a technical explanation here: http://en.wikipedia.org/wiki/G.DMT but what I am after is a layman's terms, words of one syllable answer as far as it is relevant to the end user.
I have a long line and I used to be able to squeeze 2Mb speeds out of it (= sync at 2272). For the last month or two I have not been able to stay synced at that speed 24/7 like I used to. I have not changed any settings in DMT or anywhere else. The best I can manage now is to stay at a 1500 profile (= sync at 1728) 24/7.
What I would like to know is the optimum settings to use for those items I have circled in red. I know they must have a big effect on performance because I have experimented with various settings. (For example, lowering the 'max bits/bin' setting lowers my sync speed, but it isn't a simple case of putting it up to 14 or 15 either because above a certain figure it seems to have no effect or to make the line less reliable.) I have also tried using the 'auto' settings for 'bin adjust'.
I know that there is a new bras profile of 1750 being introduced at the end of the month, which requires a sync speed of 2016. At the moment I cannot even reliably stay synced at that speed 24/7, but I used to be able to stay at 2272 24/7 no problems. I feel that tweaking the settings I have highlighted is the answer but I cannot work out what the best settings are.
Does anyone know?
Thanks in advance
Does anyone know?
Thanks in advance
