DMX Stage Lighting Controllers
smr
smr
6 Mar 2008
Leicestershire
Hi all,
Bit of a long shot but I was wondering if anyone here knows a thing or two about DMX Controlling methods / DMX interfaces or software...
I've bought a moving head light and am wondering how best and cheap to get it controlled... either software with a DMX to USB adapter or to go for a DMX interface and which is the best method. Thanks if anyone can help.
Try the blue room forums but you can get USB to DMX controllers pretty cheap if you just want it to move.
its worth mentioning that DMX isn't an interface its a protocol so make sure you get the right connections, most common is XLR 5. Afraid I only really know about static lights, never had any experiance with moving lights
Most lights these days 'dance' to the sound through a built in speaker. It has taken me years to learn this so leave off :D Oh by the way Strobes are dangerous to some people. Best put a disclaimer about that on your tickets!
I know quite a bit about lighting.
Something like that your best to use a computer controlled software. you can get the manual controllers but it takes a lot longer to create scenes e.t.c. but it depends what you want to use it for really.
a cheap alternative I setup about 8 x martin mac250 moving heads and 4 x martin mx4's a while back and I used american DJ MY DMX its about £120 for the kit and is really easy to setup.
If you want something a bit more advanced your best bet is Sunlite Suite. its quite a bit more but you can do so much with it.
If you just want to spend about £60 max get yourself a manual controller. but beware you will need to spend some time setting up scenees on it,
anything else just give me a shout
If you want
