DNS hairpinning/accessing external IP inside NAT
4 Oct 2003
Sheffield, S.Yorks
I've got a web server/file server running on a small network that is connected to the outside world via an ADSL line. Everything works great, but the problem we have is that we can't access the web site or server via the URL from inside the network, presumably due to NAT.
My question is: is there any way around this? I can use the HOST file to redirect the URL to an internal IP, but that's no good on the iOS devices we use. Is there perhaps something at the router level?
I've heard of Hairpinning but still trying to get my head around it.
Cheers.
No NAT loopback?
From experience "home grade" routers don't have it, but "business grade" routers do. Very much a YMMV.
Sorry, should have added - the router is one of Sky's own, so pretty much useless.
That said, DNS etc is handled by an Amahi VM, and I don't mind chopping/changing that to make it work.
The other potential issue is I have multiple Vhosts on the one IP. Would any solution still pass the original requested IP through to Apache so it can serve the right site?
In answer to your second question you have three options;
1.) Seperate ports for each site so users would access via
site1.domain.com:81
site2.domain.com:82
2.) An ISA type box / or free version handling the traffic
so incoming DNS would be looked at and directed at the correct back end port
site1.domain.com > server1:80
3.) Host headers where the web server looks the incoming domain requests and applies a rule
site1.domain.com = site1
site2.domain.com = site2
all handled by apache
Hope that helps
site1.domain.com:81
site2.domain.com:82
Hope that helps
Option 3 is how it works now. Apache sees you want site A and pushes the requests to the right directory. Thing is, if I have something directing to a local IP, Apache wouldn't know which URL was requested, would it?
I think #Chri5# has the right idea. Microsoft SBS does this by using authorative DNS on the internal DNS server. The URL stays the same, but the DNS points it to the private IP for internal users only.
Host headers can be done purely with domain name and can all quite happily sit on the same local IP. Thats what they were designed for. It gets a little more complicated when you add SSL in to the equation though
If the webhost content does not depend on the external domain to function, which often can be the case, you can simply substitute the external domain name for the internal domain name. This works with outlook web access for example.
external: https://owa.externaldomain.com
internal: https://internalexchangedns/exchange/ (internalexchangedns = exchange internal server name)
If you need to access it for testing, then the limitation is that you are not testing the accessibility of the nat, only that the http is up.
I think another option, but i could be wrong here, would be to have external outgoing internet go out on a different IP that the external destination address of the nat. That way when you try to access to the domain, it does not have the same source and destination address. Alternatively you could set up an external hosted proxy and access it via that.
External proxy. Now that sounds interesting.
I'm not sure how I'd set any of these DNS solutions up, unless someone can point me in the right direction?
Cheers.
As per the other thread, DNS server internally configured appropriately. Modify DHCP scope on the router to point to that server for DNS
If the router wont let you modify client DNS in the DHCP scope, disable DHCP on the router and set that up on the server too
Well, I did have DNS and DHCP handled via Amahi, but I've just killed that VM and added the required roles to my Windows 2012 VM. I'm told split DNS is easier via this method. We shall see!
I've got a similar thread running on AVForums if anyone fancies a wander over. Same thread title.
DNS and DHCP are incredibly simple on a windows server. Configure a forward lookup zone for your domain, add the hostname to it with the internal IP, set a forwarder for your ISPs DNS....
Configure DHCP to give the windows server as the DNS server, the router as the default gateway. Job done
It's really simple, not sure why the thread has gotten so complicated
It's simple for someone who knows what they are doing and they know IT acrynoms. Not everything is simple in the world especially if you don't know what you are doing or don't understand the concept.
You need to know how Windows Server works, too. Windows Server 2012's nothing like the systems I've used before. It takes a bit of clicking around before you understand how it's wanting things doing.
If you don't know the acronyms and aren't interested in learning off your own back, why would you bother playing around with servers at home?
