DNS / Hostname
5 Feb 2006
K ive been trying to connect to a Ventrillo server , its a voice communication thing for those that dont know :). I know the adress and port number are correct. When it try to connect it tells me Unable to resolve DNS / Hostname , what the hell does that mean o_0 , skype doesnt work and neither does msn audio conversaion. Im on a wireless router but this hasnt happened before. Is it my net screwing up ?
it was a ventrillo ip adress but ive done the same thing for ages and it hasnt given me this turd before. Also a lot of sites dont work and come up with "www.????.com could not be found , please check name and try again". Its like it just cant connect to them or something .. ? :(
Probably because those DNS records still work, or your PC's caching them.
Obvious solution's to use someone else's DNS records, eg 212.159.6.9 is one of Plusnet's.
how do i use that ? o_0
on my network connection deatils , so this is the details of my wireless connection to the router it says DNS server 192.168.0.1 , is that right ? or is that a problem
