- 5 Jan 2010
I'm on O2 broadband.
They have given me an O2 Thompson router which is useless - it's slow, it has no options, I get higher ping in games, and some things just time out instead of connecting properly
I have a Linksys WAG320N that worked perfectly with BT, although with O2 it works fine but then after a random time (30 minutes to 5 hours) it just stops working. Steam, MSN, and other things still work - websites just won't load. If I use OpenDNS though, it works fine, although this is not an option as some of my devices do not support it, plus it's difficult and annoying having to change the settings for when I go to work and use the wireless there.
I've even tried cloning the O2 router's MAC, and manually inputting the DNS settings, but the same problem still occurs
Any ideas on what I can do to fix this?
Thanks
Thanks
