Recently I purchased a 27" Iiyama B2712HDS which emitted a subtle buzzing/humming/whining sound when the brightness was reduced to below around 85/90%, upon returning the monitor I was told that all monitors of this size make subtle buzzing sounds at low brightness, how true is this?
As the monitor is used in a 95% silent office, I could easily hear the monitors noise over everything else in the room, which I found unacceptable and managed to get my money back. So, I am now back in the market for another monitor of similar size, about £280 budget. I was very happy with the Iiyama overall and was tempted to order another one, hoping that it was just a fault with the old one, but I am reluctant to go through the stress again if they all do it
I read around on a few sites that the noise is caused by the back-lighting method in certain LCD monitors and can be avoided by using one which uses LED instead, I cannot see any LED monitors of this size in my price range though, so not really an option
I realise that using the Windows options to reduce brightness is a solution, but as the monitor will be occasionally used for games consoles/dvds, it is not completely viable.
What I am trying to get at is, are there any monitors of around 27" with a HDMI port, which do not make a sound when reduced to low brightness settings, within my budget?
Cheers
I realise that using the Windows options to reduce brightness is a solution, but as the monitor will be occasionally used for games consoles/dvds, it is not completely viable.What I am trying to get at is, are there any monitors of around 27" with a HDMI port, which do not make a sound when reduced to low brightness settings, within my budget?
Cheers
LED's tend to last longer than CCFL's also, meaning LED is probably cheaper in the long run.
