It's actually putting me off buying a new TV, as I keep thinking, well maybe next year they'll finally put that 25yr old (gigabit) socket on a TV.
I've tried wireless and it's just not as reliable and solid as a dedicated wired connection. My primary issue is with Plex, which with high quality sources can get near/burst 100Mbps.
Yeh, tried that. The problem with that is is then stops YouTube casting from working for some odd reason. Guess because the TV looks at its ethernet and its wifi and sees no connection?You can get USB 3.0 to Gigabit Ethernet adapters that work quite well with certain TV's like Sony.
I'll try my USB->Gigabit ethernet adapter again. But I'm fairly certain, it breaks the YouTube cast feature on my LG E7 TV.I know technically that TVs with a good wifi connection should never face issues with live steams even of high bitrates. In reality though, for whatever reason, they still do. Gigabit would eradicate any such bottleneck for a very long time even up to 8K streams (not that we are anywhere near ready or demanding of that). They skimp because they can. Try a USB to gigabit adapter in all of your ports and see how you get on. The results can be surprising. Some of the ports are USB2, some USB3. Some of them seem to be nerfed from working properly. Some don't work at all depending on TV and adapter combination. In my LG OLED I think I can get about 300mbps with one off the top of my head. There is another thread about this where rates were posted.
Well, I connected my E7 to my wifi network, and with a speed test (via the TVs browser) is was literally bouncing just below 100mbps. Just like my wired connection. So I assume it's a chip limit in the TV?My TV gives me approx 300Mbps over Wifi (5Ghz)
TBH I'm not sure I test the speed results from the brower in my E7. The browser feels very slow and clunkyI have a Docker called LibreSpeedtest on my NAS so I can run internal speed tests to anything that has a webrowser such as my TV.
I have a samsung TV with 100Mbps port and can play large Plex files locally (LAN) and even had other people with a Samsung TV do the same from my server remotely (1GBPs connectins at both ends) remotely.It's actually putting me off buying a new TV, as I keep thinking, well maybe next year they'll finally put that 25yr old (gigabit) socket on a TV.
Next tiime I get some buffering (over lan), I'll try wifi out of interest.The Above didn't work on my LG OLED B7, I've got the Force Direct Play option but not the Disable Bitrate Limiting one. Playing a 4K rip of John Wick 2 has it buffering a few times in the first couple of minutes when it's wired, but switched to WiFi and it goes away.
