I have just built my new system
Core i7 920
Noctua CPU Cooler
Silverstone TJ07
I was wondering if replacing the case fans with more powerful ones will they reduce the CPU temperature as well as the system temperature?
The CPU runs at 37/38C idle, not done any load testing yet, while the system temp is about 47C.
As the CPU cooler is mounted horizontally so the fans point upwards to the top exhaust fans, I am thinking to disconnect the bottom CPU fan as it may be pulling hot air on to the cooler from below. Any thoughts?
Many Thanks.
Core i7 920
Noctua CPU Cooler
Silverstone TJ07
Many Thanks.
