- 18 Oct 2002
Hi All,
Bit of a weird issue. I'm have a Ryzen 3900X with a Gigabyte X570 Aorus Master motherboard.
I tried to turn it on this morning and nothing happened. I removed the battery and put it back and now the fans spin, but nothing else happens.
The board LED shows error code 00 - The manual doesn't have a 00 code but does have a D0 which means CPU initialization error. The CPU LED on the board is also lit which means there's a CPU error.
I've not used AMD for nearly 20 years, so don't know if this is a common issue. Surely it wouldn't just die? Or could it still be a motherboard issue?
I've never overclocked it and the temps were always fine. It just seems really weird.
