Do Displayport Cables Come With Monitors
13 Aug 2004
Hi all, silly question but I was wondering if monitors come with a displayport cable? I am looking to buy an AOC G Sync Monitor and I wondering if it would come with one or would I have to order it the same time from Overclockers as the monitor?
Thanks.
Yes, it will come with a cable. IIRC, g-sync only works over displayport so you wouldn't have a fully functioning monitor if it came without one.
My Samsung 4K monitor came with a 2 metre DP cable, which wasn't long enough. I had to buy a 3 metre cable.
As above the only issue I have had with the cables is the ones supplied are not very long ... so if you have a standard length one now then you should not need to order one :)
