Hi i have this case the Corsair 600T http://www.overclockers.co.uk/showproduct.php?prodid=CA-043-CS&groupid=2362&catid=1489&subcat=
It has 2 x 200mm case fans and i also run 2 x 120mm on a rad for my CPU.
Well today i was noticeing the smell of my case getting hot
Touched the sides at it was hot, my cpu had got to around 75c when its usualy under 60c.
Then i noticed my cpu/rad fans weren't spinning and my top 200mm was but just and the led light was off and my front 200mm wasn't moving either
So i turned my fan controller up full and they all kick in and the leds light up bright.
But if i turn it down slightly they stop!
I use to have the dial on the lowest no problems, its like theres not enough voltage.
Any help would be apreciated, do you think i need to buy a seperate fan controller or at the least connect my 2 rad fans straight to the board?
Thanks
Thanks
