Do fan filters increase temps (and other questions)
2 Feb 2009
My 2 pc cases get pretty dusty so I'm thinking of buying some fan filters. I've got a few concerns about doing this though so hopefully you can answer my questions...
Do fan filters increase temps? If so how much on average?
Do they reduce airflow? If so how significant is the reduction? (I guess that's the same question as above)
Do fan filters need cleaning regularly (I assume they clog up with dust)? How frequently and how do you do it?
Are all fan filters the same or are some better than others?
The next two are probably stupid questions as the answers seem very obvious but I may as well ask while I'm here... Do I have to add filters to all open vents as well as the fans? Is there a need to put filters on exit fans?
One of my pcs (the one used as a media centre) has a passively cooled cpu (AMD 9550 with Mini Ninja heatsink) and a passively cooled gpu (ATI 3450) using only the case fans on the slowest setting in the Antec Fusion case to keep things cool - would adding a fan filter to the case fans and vents mean I'd have to turn up the fans?
The other PC has an OCed ATI 4670 and I'm planning on OCing the AMD 5600+ (hopefully to about 3.1MHz) which has a Ninja mini heatsink & fan so I've very conscious that I want to keep airflow high. The case is an AC Silentium T1 Pro and attracts dust like nothing I've seen before - especially through the bottom air vents which look fully clogged up.
Pair of old stockings! Make sure they are clean though. I can smell the wives hoofs each time I turn mine on :p
Cheap as chips solutions was brought to you in assocation of Admiral Huddy
:) Whilst I'm sure that will reduce dust, is it as good as a proper fan filter? Do you actually do that on your pc? How often do you wash them & would you say your temps are higher?
That's only in my case though, in my brother's Antec they are so dusty and horrid yet the temp change is barely any different. I have quite quiet fans so they don't push as much air which is why any obstacle increases the temp so much. Mind you it's only 30C max inside and eventhings else is still cool so it's not an issue.
I take it you don't overclock anything if it's only 30'C (up from 20'C) in your case? Does your brother have better fans / fans on max speed?
Yeah I overclock a lot, and my PC is under load most of the time it's on. I have a Q6600 @ 3.7Ghz and a heavily overclocked 8800GTX. The CPU and mobo are under H20 though. My bro's got the fans on 'high' in his case so they are loud but shift an immense amount of air (Antec 1200), where as mine would be below 'low' ont he same scale, they are run at 5v.
I didn't fully realise how much difference water cooling made. Is there a reason you don't push it further an take temps of 40' - 50'?
We'll they are only on the bottom inlet valve because that is nearer the floor and that one picks up the dust more. I've not noticed any rise in temps tbh.. They are fine and they are stretched over and held in by a rubber band. Strecthing them improves air flow but still does a fine job!
I don't clean them.. I chuck 'em away and replace every month.
Don't use fishnets though.. although that is quite appealing for me :p
That's a whole new genre of computer porn... :D
I just shove my antec 300's filter under the tap, leave it to dry for 5 minutes then put it back in.
Doesn't make any difference I can see in the short term, and in the long run it certainly keeps the temps down by stopping everything clogging up with dust. My old P4 gets clogged up very easily, and that can increase temps by 30c!
They do reduce airflow, but if you have enough anyway it won't matter. Better to go up a few degrees now than risk going up a lot when you aren't watching it and blowing something (or even just losing performance/increasing noise)
Sounds like sensible advice.
I guess now the question is just tights or filters?
Positive air pressure helps too - more air going in than out.
I'm about to cut my fans down to 2x120mm intake, 1x140mm exhaust. I'll be blocking up every other gap I can find in the case with magnetic strips (like the stuff you get on fridge magnets). That should mean that my intakes are dust-filter'd and air is blown out of every other orifice = less dust.
Why magnetic strips? Is it just because that's the easiest way to block them on a metal case or is your reasoning more scientific? Will you be using filters on your 2 12cm fans?
