i think the gold plated stuff its more aim at wear, when you pull out and plug in often. so doesnt wear out as fast?l
It's a lie to get mugs to buy their cables.I was looking at getting a dual link DVI cable from somewhere and in its product description it said "Gold-plated contacts provide full conductivity whilst preventing ghosting and data loss." so I doubt that is true, a normal one is probably the same. It also said it was triple shielded, i guess this helps prevent inteference right?
platinum cables and moon dust solder rinsed with water from the fountain of youth = perfect clarity , no ghosting , reduces your monitors reponse time by upto 500%
only 9.95 !
