To cut a short story shorter, there's a 172 Cup being offered for a pretty cheap price an I'm in two minds about going for it.
The pros are:
Half the milage of mine (35k)
53 Plate (Mines an X reg)
It looks damn good on the outside
And the cons are:
It's more of the same, and taking mods into consideration whilst it probably handles better I think mines a touch quicker straight line, but I bet it's negligible.
I know mine inside out, had it for 37k or so now and know everythings ok. There are loads of unknowns/potential problems with getting another one. Still on standard exhaust and needs cam belt doing end of the year.
It looks horrific on the inside
Drab grey cloth seats that whilst ok to sit in look horrible.
No ABS, not a huge concern but more for when the other half drives it.
So not sure if it's worth the 1-2k cost to change, after taking into consideration buying it and tidying it up, to basically just get a newer lower milage version of what I already have.
It's also been heavily tracked in that 35k, approx 300 laps of the ring. It's also used as a daily drive and I don't really see any of this being a problem, but maybe some things might be more worn out due to this.
Plus it's about 250 miles away
What would you do?
I can find pics of mine and the potential if it helps...
The pros are:
And the cons are:
What would you do?
