Phenom II 955 with a VID of 1.35V.  Isn't that a tad high for a 45nm chip?  I'm not having a lot of luck overclocking either - even a small boost to multiplier or FSB speed results in a crash when running Prime95.  I thought these chips were supposed to be capable of 3.6 to 3.8GHz on stock volts?
		 should be around 50-55 under load, phenoms become unstable over 62 degrees which would explain why you're getting errors in prime...
