http://www.guru3d.com/article/amd-radeon-hd-7750-and-7770-review/7Subjective obtained GPU power consumption = ~ 43 Watts
I dunno, the HD 7750 is a low power card, but the E5200 is still rated 65W and there are other components that use the 12V rail so you will really be pushing it- especially considering these are not super-cheap components.
as it would be the perfect size for a nice HTPC system.
, you might see it crop up in project logs sometime.
Not sure on pricing, but can't link to competitors anyway! I'm sure Google will help you
EDIT: seems around £60-70
http://www.guru3d.com/article/his-radeon-hd-7750-icooler-review/5
According to the link, the 7750 requires at least a 450W Psu on an average PC.
System Wattage with GPU in FULL Stress = 185W
Here is Guru3D's power supply recommendation:
Radeon HD 7750 - On your average system the card requires you to have a 450 Watt power supply unit.
Also it doesn't have to be a 1u shape specifically so long as it is quite small, there are many places I could put it
The one I have is 150mm x 81mm x 40mm
250W Seasonic Flex ATX 1U PSU
Output Power: Maximum 250W continuous
Efficiency: >80% - 80Plus Bronze Certified
Voltage: +5V +12V -12V +3.3V +5Vsb
Max Load: 17A 18A 0.8A 14A 2A
*Max Combined load for +3,3V +5V 110W
*Total output power for this power supply 250W
Do you think this would be adequate? It's exactly the same dimensions as my 200W PSU
