Do i need 3 way SLI GTX 670?
4 Mar 2007
Hi Guys
Ive just setup 3 monitors to give bf4 a try using spanned displays, ive found it to be a little juddery using 2 way sli.
Would 3 way sli make it a better option as ive found somewhere selling a matching card.
My system setup.
Intel i7 990x 6 core
12gb ram
Evga x58 board.
1000W PSU.
250gb SSD as boot drive.
Cheers.
What resolution is your 3 way?
57xx by 1080?
If so then you need a lot of grunt to play it at high settings. SLI 670 might just not be enough.
Although as hinted above, if you're using 2GB versions, then the 'juddery' feel might be you running out of VRAM, in which case a 3rd card wouldn't do a single bit.
