Just wondered as the fans i'm looking at for my H50 are 3 pin. Can i just connect one of the 3 pin fans to the cpu fan header even though it has 4 pins?
4th pin is used for controlling the fan Via PWM, you'll be fine running a 3 pin fan although a fan that makes use of PWM will be a lot quiter when its not under load.
Great stuff cheers, well i've ordered a couple of Scythe kaze jyuni 1900rpm now for push/pull so hopefully they'll bring down my temps a bit. Not too fussed about noise really as long as my cpu runs cooler
